I need new shocks
Backlash2032
1,823
Nebraska
a quick question.. shocks at autozone are either 12.99 or 74.99 each. Obviously I'd go with the 74.99 ones.. but tokicos are only 68.99... I can only afford one set right now, so would it be bad to run the tokicos in the rear and stickers up front?
I would think so, but just thought I'd check with you guys.
Sent from my DROIDX using Tapatalk
destrux
1,183
10
PA
12.99!?
Do you mean $112?
You can mix them if you want, it's not optimal, but still safer than blown shocks. The tokico blues aren't much stiffer than stock anyway.
Backlash2032
1,823
Nebraska
Yeah, i would get them, except for the fact they would blow when i set the car on the ground.
So no problem with using tokicos in the rear until i can afford getting lowering springs and the front shocks?
How did you come to this assumption?
If you're strapped for cash it'd be smarter to grab 4 of the cheap shocks and have a balanced car than half assing it...
