I need help with my throttle stop screw
dylansword
114
boise id
Hey guys. So I messed with the throttle stop screw on my 87t ages ago. And now I'm almost done building my car up. And I need to figure out how to get the throttle stop adjusted back so stock so I can get my tps adjusted properly. Any help would be awesome! Thanks
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Back it out until the throttle is fully closed. If your ISC valve is working properly, backing out the set screw all the way won't drop your idle below the ECU's target value.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
1) Disconnect throttle linkage by popping off the rod.
2) Set throttle stop so throttle plate is just fully closed.
3) Set IDL contact in TPS per TSRM
4) Set dashpot per TSRM
5) Adjust rod length if needed to maintain closed throttle and reconnect.
