I NEED HELP WITH MY CODE 34.....i have tried many things to solve the problem
mk3supraoz
133
So. Cal
okay guys i keep getting code 34....... adnormal turbo pressure (fuel cut)
i have an 87 supra turbo auto. as soon as i installed my cooleeze dp, tp, ex. sys, icp, xs bov and shim my wastegate i keep getting code 34. Im only pushing 10psi and using and a hks boost guage. I have tried unshimming my wastedgate, checking for leaks, changing the afm....i need help this is driving me crazy. :icon_evil As soon as i gun it about 4500rpm bam fuel cut.:1zhelp:
smagnotta
SuprSal
WashPa
Sounds like you need the Lexus AFM upgrade (with 550 injectors if you can), or the MAFT Pro if you do not already have it.
oscarsupra
El Salvador, Central America
Check the wastegate.
Maybe is giving you problems. I had the same problem whit my car like 2 months. I changed the wasgate and the problem was solved.
Code 34. This only talk about the turbo but wastegate is a part of the turbo.
Try to change the wasgate or the turbo if you can.
