I need help with an an unplugged wire in the engine bay
den7
8
New Zealand
Hi, Can anyone tell me where this wire plugs in? I had a water leak in the pipes behind the manifold and I found this wire unplugged after I put everything back together... I had a look for where it might go, but I couldn't find it. Checked the TSRM, but I had a lot of trouble working out the locations of the plugs in the diagrams. The wire is long and is on the exhaust manifold side. Colour is Yellow with a Black stripe. Photo attached. Thank you for any help.
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
Um it might even be the plug for the oil pressure sending unit. Kinda looks like and iirc the wire is yellow.
shaeff
Kurt is FTMFW x2!!!!
11
Around
DAMMIT! i wanted the cupie doll!
yes, oil pressure sensor- it slides on sideways
den7
8
New Zealand
Hi all.
Thanks for your replies. Wire is plugged back in where it belongs. Was at my wits end last night, especially after pulling everything to bits. Whoever put those heater pipes back there has a twisted sense of humor...:rolleyes:
