Thanks oldsking! I'll have to check out your build thread.
The fuel housing has a -8 feed and -6 return. The pumps are (part#50-1200) AEM 320 LPH @43psi or 84GPH compatible with gasoline, ethanol and methanol. 1 pump claimed ratings capable of supporting over 500 whp. Also have the Fuel Labs filter 6 microns -8AN (part#81832-1).
I removed the stock rubber gaskets from gas tank and replaced with Fel-Pro Karropak gasket material for ethanol fuel. Also used Permatex permashield gasket dressing.
