I finally got my 7mgte to start and it runs great no misses revs great only problem is it wont idle
im not sure on exact rpm because its a n/a tach and turbo ecu but it idles high and steady for a while
until it warms up then it starts hunting for a idle speed it goes from around 1000 to around 2000 to 2500 then back down. iv already searched for vac leaks adjusted cps and tps with no improvement. if i unplug idle air control it does not run any better or worse so i am thinking that is the problem but how do i check it to make sure? also does anyone have any other suggestions on what my problem could be
