HP numbers and Track times
Supra5MGTE
421
Tampa, FL
Wondering what these mk3 turbos run at the track. 1/4 mile. I don't see any around, so... have no idea. Wondering how fast our '90T Auto would be with a Test pipe and Catback. I used 20HP gain for cat back, 10HP gain for test pipe and 230HP stock. punched in 3600lbs for the car in the calculator and said about 14.991 ET. way off? What are you guys running and what do you have done?
SidewayzSupra
Puyallup
I wouldn't give 30hp for that, but I would give around 35 for a full 3" downpipe to muffler. Thats just what I've researched. I\d guess depending on driver and condition of car mid 14's??? My guess.
8,900
Sports Car International, February 1990
0-60 mph………..6.73 sec
0-100 mph………17.13 sec
¼ mile…………..15.25 @ 93.9
Top Speed………146 mph
Skidpad………… .85g
Braking 60-0.……126 ft
Braking 100-0.…..227 ft
5 speed manual
United States Auto Club certified performance
0-60 mph………..6.7 sec
Car and Driver, April 1989
0-60 mph……….6.2 sec
0-100 mph……..16.3 sec
0-130 mph……..35.5 sec
¼ mile………….14.7 @ 95
Top Speed …….146 mph
Braking 70-0.…..176 ft
Skidpad……… .85g
4 speed automatic
Road and Track, February 1990
0-30 mph………..2.5 sec
0-60 mph………..6.6 sec
0-100 mph………17.9 sec
¼ mile…………..15.5 @ 93.5 mph
Braking 60-0.…..146 ft
Braking 80-0.…..279 ft
Skidpad……….. .83g
Noise idle……….42db
Noise 70mph……67db
Motor Trend 1991 ran an auto and did 15.7 @88.
Stock will vary with the different wastegate acutuators, and the factory allowable tolerance.
americanjebus
Mr. Evergreen
wa.
yea stock auto your gonna do 190 to the wheels. those mods, you'll be arround 220 wheel or so. low 15's . some drag radials, perfect elevation and ambient temperature, and a perfect dead on launch and a perfect engine. perhaps 14.99 but dont bet on it.
8,900
Unfortunately, you didnt list a weight. And ET is based on multiple factors, unlike mph. Traction, gearing and area under the curve determine you quick you get to the finish line.
With a curb weight of an MA70 turbo and a 200 lb driver, you need 350 hp to travel a quarter mile in 12.9 seconds. That does not take gearing into account.
Supra5MGTE
421
Tampa, FL
M'kay. so we're around 15.0 E.T. Titan downpipe & T4 is next... the stock exhaust is so crumby.... These cars are HEAVY I'm beginning to see. My mk2 weighed 2,900 stock curb weight. I've pulled about a solid 500-600lbs out of it. so it's sitting around 2,400lbs at most.
Spiv
hooligan
Orlando, Fl
I think you'll get better than 14.99 with those mods. Bone stock with the boost kicked up to ~10psi I did 14.7 @ 94. The auto is maybe going to be slower, but I see a lot of auto guys around here running some very respectable times.
A downpipe with a real 3" elbow makes all the difference. though, I doubt you'll be dissapointed.
Marcenator
Marc T.
Apr 29, 2005
22
Edmonton, Alberta Canada
As per my sig.
15.2 @ 93.5mph Bud Park Edmonton, AB
225whp 275wtq Dyno'd at Apex Modified Edmonton.
Only mods so far:
Shimmed wategate to 10 psi
Electric fans (dual Flex-a-lite)
A/C Removed
Stock intake and exhaust
Auto tranny
It's a good start with plans for dp, intake and boost controller over the winter.
P
Pokey
Guest
i made 225whp and 272wtq with intake and shimmed wg to 8psi and ran a 15.0 at 93mph with a 2.2 60ft, on the first run ever down the track with my car, and auto to 5sp swap
jeff
suprarich
Guest
Nov 9, 2005
2,187
ohio
I ran a 12.35 at 116 mph with only 366 rwhp in a full weight 88 5spd. It does not take as much Hp as everyone says.
