shaeff:shaeff said:he's implying that the N/A cam GEARS are identical to the turbo cam GEARS. it's the INTAKE CAM that's different between turbo and N/A models.
-shaeff
Sabotage said:shaeff:
So you have your wg shimmed and an MBC? does this cause the wastegate to not open while building boost. I know that our WG's open as soon as you hit boost and are fully opened at Xpsi. I hear an EBC will fix that issue totally this correct?
as i thought, thanks for the answer :biglaugh:shaeff said:the springs in our wastegates are getting old and tired, so they start to open EASIER than they should. i put the washers on there, along with the MBC to allow me to hold my max boost right until redline. no matter what you do, the wastegate will start opening at positive pressure UNLESS you get an EBC, in which case it will stay totally closed until your desired boost setting is reached.so yes, that's correct (which is why they help spoolup time as well).
-shaeff
