ok i'm going to just go ahead and say the main parts,
7mgte
adjustable fuel press reg "aeromotive"
fuel pulse eliminator kit "supra sport"
EGR block off plates
MAP ECU "removed MAF"
k first pic,
i have a oil catch can, its got 3 ports "2 on top and one on bottom" do i just run the two valve cover nipples to the two top inlets on the catch can and then the bottom inlet/outlet on the can to the 12264a or can i just block it off and have it fill the can? or just be a dick and have it going on the ground all the time
2nd pic is a example of how my EGR system is currently, blue is the block off plate locations and the red is all removed items. does it seem right?
3rd pic is how i think everything should be routed for vacuums, i still have my power steering, but i am removing the EGR system completly and the charcoal canister. all the red is removed and the yellow is for the vacuum for the fuel pressure regulator, and the purple is for the PS. as for on the TB i just put some caps on them to block them since i wont be needing them?
last but not least, have this intake now
now i need to make sure that since this 4inch pipe doesnt have any nipples and is just a big pipe that i have eliminated so i dont need to weld any nipples onto the pipe, the last picture is basically what i'm trying to accomplish, the black things would just be caps or just nipples that are removed
7mgte
k first pic,
