How in the %$#@ does water get to the spark plug galley and only foul #3and #4 this is just busting my ass. And there is no other sign of water/liquid anywhere else, not to mention it runs like shit after that.
Jet
Jet
Dan_Gyoba;896932 said:Coolant leaking from the throttle body line?
Poodles;897502 said:there are a number of threaded plugs in the head, the ones on top that hold the center gasket down go into the oil galley, and the ones down in the spark plug wells (there are 3, one between 1&2, 3&4, 5&6) go into the coolant jacket of the head.
Sounds like you need to remove the plug and reseal it with sealant...
Poodles;898717 said:Autozone carries the required tool to remove them (comes in a 3 pack of I think 12, 13, and 14mm)
Might require an impact to remove though. There is a writeup on cygnus: http://www.cygnusx1.net/Supra/TechTips/head_coolant_leak.aspx
shaeff;900326 said:pics or ban.![]()
Jetfixr757;900859 said:You are cruel...want me to run it again to get pics of the leakey head, you are not only cruel but wicked, i was on the verge of vomiting when i saw them.
Jet
shaeff;901492 said:no, i didn't want you to run the car again, i just wanted pics of where it's leaking from.![]()
ATL88Supra;901255 said:i had that happen to one of my heads had to replace it
