how much will a stock 1j clutch handle
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
well about to start on my 2j swap(r154)..and i am more going with bpu's and calling it a day..i was just curious how much hp the stock 1jz disc can handle? i searched couldn't find anything thanks
empera
Authorized Vendor
Philly.
not much, mine started to slip at around 14psi....dyno put down around 276rwhp at 11psi...so if i were to guess anywhere near 300rwhp but i may be wrong
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
o damn lol that was less then i expected i am just not sure if i should go with a aftermarket set up or not its going to be my daily too..i will probably just spend the money and go with a aftermarket set up..i was thinking spec. still looking though i am defiantly not in a hurry
Albert
May 13, 2009
1,710
Tempe, AZ
Hmmm Dustin made 420rwhp on a stock clutch and stock PP on his 2jzgte with 67mm at 19psi. slipped at 22psi.
Albert
May 13, 2009
1,710
Tempe, AZ
2jz dont hardley make any torque to break the stock clutch loose. My 1j did it all the time. So much for 2js having "torque"
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Albert;1783645 said:
2jz dont hardley make any torque to break the stock clutch loose. My 1j did it all the time. So much for 2js having "toque"
Ya my motor has torque...idk what toque is? Might want to get that fixed
gurley0916
Mar 10, 2008
1,138
Columbus,OH
Ninja edits dont work when they were already quoted.
But seriously I feel like my stock clutch was a freak and I feel that I will never see another one do what that one did
te72
Classifieds Moderator
6,626
10
WHYoming
Ninja edits work just fine. My stock clutch/PP setup held just fine at around the 320rwhp mark, not sure how much torque I was making though. I'd figure on upgrading, if nothing else, to a slightly stiffer pressure plate, but no real need to go with a puck style clutch unless you start pushing 400+.
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
empera;1783624 said:
any time bud...mw3 soon? maybe tonight or tomorrow night i'll be on
i am on all the time bro lol..
yea i will probably just go stock clutch and fidanza flywheel i just want 300hp to wheels and good dd.
my buddy mad 410hp on 7m stock clutch and it barely started slipping hopefully my jz clutch will hold like dustins lol....
JPsToyota
231
East-Central, FL
My stock R154 clutch was just fine on the street at 17ish psi on a single 1J setup. 320-340ish whp maybe? Ran pretty well.
Took it to the track and on my second run pulled a perfect launch and then roasted the clutch the whole way down. That was the end of my stock clutch days.
It was an older clutch, but on a bpu 2J I wouldn't even bother with a new one. It won't hold up to hard driving. Upgrade it.
Good luck!
