How Much to do a headgasket job
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
A couple of years ago it ranged from $1600 to $2300 depending on the shop and what they thought they might run into. It cost me $750, including a few necessary tools. If you can get your hands on a garage for a couple of weeks (just in case it takes a little longer for your first go), this is definitely the only way to go, just like selfinfliction said. :)
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
Do it yourself. Get a few buddies to help you out when you start getting pissed off cause a nut/bolt wont come off. Put everything in zip top baggies and label them all. It is not a hard job at all, it is just time consuming. Get the head cleaned/checked for warpage. And use the search feature to look for answers. If you do it yourself, you will gain good knowledge about your car. Plus, its almost like a rite of passage lol.
:word8kn:
plus you make a few good friends for life from supramania.com....:naughty:
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
I couldnt have said it any better.
do what he said
JDMMA70
2,550
Houston
i guess a dealer would charge the most Toyota said $1400 for parts and labor and machine work is extra if the head is warp if the block is fucked to then they add on more
cuel
1,536
Baytown, Texas
Depends on your location, and what the hourly shop rate is. Every shop is different.
Typically, I could probably do it for $1500 with all new parts(h.g. kit, oil pump seal, w.p., timing belt, hoses, radiator sent out to be checked and cleaned/repaired or replaced as necessary, t.stat., etc.), head machine work(including valve job), and labor. Getting the block decked will add quite a bit to the price(I'd have to pull the block, disassemble it, get it decked, put it all back together, etc.).
