How much boost PSI are you running?
Feb 24, 2006
187
Los Angeles
does anyone know what the max boost i can run on 440s with a to4 turbo? i'm hoping to hit 18psi, but i don't know if im going to be maxing out my injectors or not.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
i ran 18psi daily on mine with 440s and a 60-1 single, afr's stayed in the 11.2-11.7 range the entire time, even took it to 21psi on accident and it still stayed in a good afr range
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
sc250tt;1065797 said:
Its been at 20 psi for almost 2 years and still no smoke . Im running a hks evc and a hks fcd on stock fuel with the exception of a supra tt pump and 12v mod.They loose effiency after about 120 mph or so .I am automatic with a stock dp thats probably one of the reasons they haven start screaming and smoking yet .
Actually...
If you're running a stock downpipe, with 20psi...
This would be more likely to cause failing turbos.
When you're running that much boost, restriction is the last thing you want.
(ie. Running a 7M at 20psi on a CT26 with a stock exhaust).
You're choking up those turbos when they really need something well-flowing enough to let out all those exhaust gases.
Very gutsy, though. ;) Got any numbers?
Jeff
sc250tt
twins @20 psi
Mar 22, 2007
10
florida
Boost Lee;1075818 said:
Actually...
Jeff
Actually if those ceramic babies spins more than it is doing right now they have a greater chance of disintegrateing. I have a 3 inch exhause split to 2 1/2 in the rear with no cats or resonator so im still getting most of the backpressure out at a decent rate ,the other thing that puzzels me is everyone i know with a downpipe blown their twins .I dont have any numbers but when i do get some i will definately post it up .
sc250tt;1076809 said:
Actually if those ceramic babies spins more than it is doing right now they have a greater chance of disintegrating. I have a 3 inch exhaust split to 2 1/2 in the rear with no cats or resonator so im still getting most of the back pressure out at a decent rate ,the other thing that puzzles me is everyone i know with a downpipe blown their twins .I don't have any numbers but when i do get some i will definitely post it up .
It is really funny how often this argument comes up. :)
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
12 PSIG on CT26 w/following mods: Forge adjustable wastegate actuator, 7MGTE w/HK$ stopper head gasket and ARP head bolts, APEXi intake, Cooleze turbo inlet pipe, LIPP 2.5" hard pipe kit, LIPP SS 3" turbo elbow, RT 3" downpipe, 3" RT Cat, 3" exhaust and muffler. Van
Wait a minute, did i just read 7m??? I thought this was the other engine tech section.:biglaugh:
sc250tt
twins @20 psi
Mar 22, 2007
10
florida
Lol seriously....But im going by experience .This is my 3rd 1j sc. Its either im just lucky to get perfect engines or its becuase i never had a downpipe. oh well only time will tell.
