How Long And Hard To Replace 1J Turbo's?
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
2 guys that I know that have taken them off is OneJoeZee or werewolves182. PM them, they might have some advice for you. I think I'm taking them off next weekend to install a y-pipe.
Van Diesel
Powered by vino
Dec 12, 2006
396
El Paso, Texas
I removed two sets (both to go single or large twin turbo). Both times it took me appx. 1.5 to 2 hrs. Lots of cursing ensued. I never want to replace the stock twins.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
It took you 2 hours to do Mark's twins, wow. The write-up I was sent on how to remove them said 5 hours. Question is, how long total to completely replace the pair with a fresh pair? That is, for a guy who has never done it before.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
im tearing mine down now
only worked on it for about 45 mins total and i got the front pipes off and heat shield.
just need to remove the oil lines and what not and then try to remove them
is it easier to remove them from the mani's or remove them and mani's together?
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
You gotta understand that Aaron has a lot of experience with the 1jz.
Van Diesel
Powered by vino
Dec 12, 2006
396
El Paso, Texas
The first time I did it took me 2 hrs. No experience whatsoever with the motor. 2nd time took about the same...maybe a hair less.
The Reaper
Jan 10, 2006
1,909
Florida
lol the only bolt i had a hard time with so far is the heat shield bolts
rusted to fuck
haven't played with the mani yet
so do you leave them on the manis? or take the turbos off seperately?
The Reaper
Jan 10, 2006
1,909
Florida
thats what i was thinking
taking the two nuts off up top and only one underneath
vs 3 up top and two or three underneath
cool thanks
Shadow
87 1JZ-GTE Single Turbo
May 25, 2005
304
Windsor, Ct
It's not that hard. Even for someone with not much experience. Just remember how you took things off and where things go. It's doable in a driveway but don't park behind anyone in case you run into some issues and get agrivated. :biglaugh: Don't want to block anybody in overnight.:biglaugh:
