How important is the P/S pump Air Control Valve?? In swapping mine over from my bad pump to the new one, one of the nipples broke off. Do I need to whip out some plastic welding stuff and get it back on, or can I just bypass it?
speed;978662 said:How important is the P/S pump Air Control Valve?? In swapping mine over from my bad pump to the new one, one of the nipples broke off. Do I need to whip out some plastic welding stuff and get it back on, or can I just bypass it?
on the pressure side of the pump, theres a big banjo thingy that then leads to the pressure line to the rack, and then the ACV (does acv = vsv?). The air valve has two nipples leading to vac lines which run back through the intake side of the motor somewhere.does the vsv connect to your pump on the old one? vs on the line like the new one?
speed;978666 said:what do you mean, fix it like a vac line? (heh, that sounds like a shitty song that would be played on the radio - kinda like 'shake it like a polariod')
*cough*
does all it need is 1 vac source? Can i block off the broken nipple (it broke all the way at the housing), and reroute that line? or does it need both lines?
speed;978671 said:Ah okay. I'll dig out the stuff and glue/melt/whatever it back on.
