How far (hp wise) can a stock ECU safely handle?
vas85
SupraNut
Sep 29, 2006
391
Sydney, AU
Hi All,
Out of curiousity, how much HP can you crank out of a stock ECU with say.. LEX AFM, Fuel Cut Defender and provided all the other goodies are in place... larger injectors, and so on.
Reason I ask this is as there is the guy with his 93 toyota pickup (7m) on GTEPowered.com claiming he's still on stock engine management.
Linky:
http://www.gtepowered.com/index.php?page=html/dconsentino/profile.php
What are drawbacks of sticking with your existing stock ECU if you're shooting for say 400rwhp+ as opposed to a piggyback ECU, or a standalone MOTEC and such?
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
Electronics:
I run straight off the wastegate which will run the car at roughly 29-30psi. VPC/AFC, MSD DIS-4 running off a custom Reg Reimer ECU. It has other odds and ends like an FJO wideband MSD window switch, autometer gauges, etc.
Doesn't look like he is running a STOCK ecu ;)
figgie
Twin Cities, Minnesot-ah
Reg Reimer ECU = the now defunct techtom (think I spelled that right).
stock ECU. Even with piggy backs I would not go above 500hp. To much ignition unknowns when it comes to timing and fueling.
Muzy
182
Alberta
I'm no expert but he is running 11-1 with 14psi of boost. Somehow that sounds incorrect
But I did not note what he was running for fuel? muzy
