im havin a problem wen i start to hit boost it seems like the spark blows out.ive tried new plugs different gaps everything,im lost.could it be the igniter or should i start looking elsewhere? thanks walter
.028 gap, turbonetics 60-1,bc 264 cams,.020 wiscoe pistons, aem ems,gm boost solenoid,aem map sensor,550cc injectersNick M;1037064 said:Also there is a code for when the igniter does not fire. 14 I believe. But that is for non firing, not a weak spark.
What mods and gap?
IwantMKIII;1037732 said:i don't know about you guys, but i've never heard of an ignitor going bad. To my understanding of my time here at supramania, they are pretty much bullet proof. There's a first for everything i guess though? I personally would look elsewhere, like the coil packs.
Nick M;1037949 said:It isn't common, but it happens. If you notice the case, it is built as a heat sink. It gets hot under the hood, and the electronics don't like a lot of heat.
antman;1038449 said:Make sure to check all the connectors involved in the spark circuit. I had a bad connection in the plug that plugs into the coil pack. It sounded like a machine gun at wot, as soon as I replace the harness. It was back to normal.
suprawalt;1038848 said:what harness did you replace?the engine harness!
supra90mkiii;1039427 said:I'm talking about when I'm looking at the tps data on my maftpro. before i adjusted it, it was about .88 so i adjusted it down to .65
