how do you know if igniter is bad?
suprawalt
62
seattle
www.suprawalt.com
im havin a problem wen i start to hit boost it seems like the spark blows out.ive tried new plugs different gaps everything,im lost.could it be the igniter or should i start looking elsewhere? thanks walter
8,897
Also there is a code for when the igniter does not fire. 14 I believe. But that is for non firing, not a weak spark.
What mods and gap?
suprawalt
62
seattle
www.suprawalt.com
What mods and gap?
.028 gap, turbonetics 60-1,bc 264 cams,.020 wiscoe pistons, aem ems,gm boost solenoid,aem map sensor,550cc injecters
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
i don't know about you guys, but i've never heard of an ignitor going bad. To my understanding of my time here at supramania, they are pretty much bullet proof. There's a first for everything i guess though? I personally would look elsewhere, like the coil packs.
V8hntr
Undersquare
Mar 7, 2007
85
SoCal
When my igniter went bad, the car started , ran for about 4 minutes then died. I replaced and then engine ran fine.
8,897
It isn't common, but it happens. If you notice the case, it is built as a heat sink. It gets hot under the hood, and the electronics don't like a lot of heat.
antman
632
TN
Make sure to check all the connectors involved in the spark circuit. I had a bad connection in the plug that plugs into the coil pack. It sounded like a machine gun at wot, as soon as I replace the harness. It was back to normal.
suprawalt
62
seattle
www.suprawalt.com
ive tried 2 coil packs to no avail.
suprawalt
62
seattle
www.suprawalt.com
thats exactly what happens it seems to run fine when cooler temps. when it gets hot it starts cutting out badly above 4500 rpm. ill be tryin a new igniter soon and we'll see if that works.
suprawalt
62
seattle
www.suprawalt.com
what harness did you replace?the engine harness!
Clueless
980
Columbus, Indiana
well, you engine just won't work if it goes bad...A few years back I was driving my honda around, without an warning, the motor just dies. It cranks and cranks but no fire
antman
632
TN
No. If you look at the wiring at the coilpacks, you'll see the harness I speak of. It has three plugs on one side and one on the other. It plugs into a square plug on the intake side.
supra90mkiii
227
Racine, WI
I'm currently dealing with the same problem, I try not to post much on here unless I am really stumped.
- I had bkr7e plugs gapped at .032, i figured it was spark blowout or the plugs were fouling, so i changed the plugs with some autolite 3923 gapped at .028. no difference. around 4000ish rpm while at wot, it misses/sputters.
- I checked ignition timing, set at 10deg with check connector jumped, 12 with connector not jumped.
- Recently rebuilt cps sensor because of an oil leak, but this didn't start right after that was replaced.
- air/fuel ratios while at wot are ~11.5:1
Not sure if this is related but what voltage are you guys getting at idle from your tps? I recently tried adjusting mine because of a code 51, and mine is about .65v i'm thinking it's kind of low.
jetjock
creepy-ass cracka
9,439
supra90mkiii;1039427 said:
I'm talking about when I'm looking at the tps data on my maftpro. before i adjusted it, it was about .88 so i adjusted it down to .65
That would be VTA. Has nothing to do with causing code 51 but adjusting it could resolve 51 for other reasons, if that makes sense. Anyway 650mv is a bit high but still OK. The point is it's not low. Besides, your problem isn't TPS related.
