how do you identify a 7Mgte
No 7MGTE here
lagged
1991 1JZ
new rochelle
heh. MOST LIKELY you should be getting your motor with a turbo, also the timing belt cover has a sticker on it that says 7M-GTE.
the intake manifolds are different. the GE has a ypipe going into the plenum, the GTE has a straight pipe that has a 3000 etched in it in big numbers.
the GTE has a coilpack which will be sitting on top of the valve covers. it also has a CPS instead of a distributor.
if its a complete long block, the most obvious sign that it is a GTE is the big piece of metal hanging off the exhaust side of the engine...
antman
632
TN
this is the most i've laughed all day!...will ups ship what your on, IJ?
