how do i get more boost?
Sassan
71
Rialto, California, United States
ok i have an 87 supra turbo and max i only boost 5 lbs. how do i or can i up the boost with my stock turbo? i would like to run 8 lbs if i can so any info would be nice thanks.
Letsride
183
NC
Theres a few options you can do, you can get a manual or electric boost controller if you decide to run higher boost later...if you only want 8 lbs then you can just shim the wastegate by putting 2 washer on it and you'll be good.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
I'm at 11 psi from a 3" exhaust, test pipe, down pipe, IC piping and IC, no boost controller or anything else..
Of course, autos will see less boost compared to 5 speeds..
barkz
363
Afghanistan
make it breathe better...^ intake, exhaust, IC/pipe, elbow. pretty basic knowledge for any turbo car.
or just throw a MBC on it and crank it! youll hit fc then just turn it down...(joke, i do not condone trying this)
destrux
1,183
10
PA
I hear they sell boost by the pound at Walmart in the deli case.... or was that bologna....
If you don't know how to turn the boost up on your car then you probably don't know enough about how a turbo works to even BE turning it up.
Go to a book store and find a book called "Street Turbocharging" by Mark Warner. Read it cover to cover... it's a great book and you'll learn alot. This way you'll make less mistakes and avoid costing yourself money.
