Basically when i put the plugs in, still thinking in a 7m point of view I gapped the plugs to like .032 ish. No codes but car runs like crap, gauge indicates up to 4 psi before totally cutting out but nonetheless only runs decent at like -1/4 Throttle. Couldnt find a cracked coil. also if at idle and just wot free rev, it breaks up too much to rev past 5800 rpm.(Sputters backfires, sounds like and ignition problem, not like its going lean etc.) basic info is non vvti 1jz. stock fuel injectors, stock coils, AFPR (set to 35psi base), t61 with tubular manifold. Plugs are Bkr7e's.
Thanks guys and Gals.
