holy crap! compression #'s
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
1=180
2=178
3=181
4=180
5=179
6=180
wow wasent expecting that!
very high huh?
thats bored .40 over with je pistons and rings and 500 miles on the motor. oh and mhg torqed down to 90ftlbs
josh930
247
NY
Those are pretty good #'s. I had a question dealing with compresson...
Can you compression test a motor out of the car by turning the crank with a socket and rachet?
Datsrboi said:
Im still trying to learn all this MHG size and all. BLAHHH.
Search is a B**** when the results are almost from every post in the entire forum ahha
Stock HG compresses to 1.37mm so the 1.4mm is the closet until you decak the block and surface the head then you add the removed amount to 1.37mm to keep you at or around stock comp.
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Wouldn't these #'s be of concern if you were to run 18psi on pump gas? Of course with supporting mods.. I was curious. I just completed a build and wanted to run 18psi so I used a 2mm TMS HG to keep stock compression. 150 -160 in my cylinders. I was a little dissapointed there were almost 10lbs different.
Datsrboi
Loud pipes Save Lives
Jul 31, 2007
797
Haltom Texas
Thank you. Can you correct me if I am wrong?
If I get a bigger HG like 2mm or how ever bigger I can go I will drop compression on a block that did not need a head resurface right? From this low compression you can run more boost?
I will be buying ARP headstuds and HKS MHG so I've been searching all day. Your post sum up 80% of what I needed to know.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Was the comp. test done warm, with the efi fuse pulled, and the throttle blocked open? you will get bigger number spraying fuel.
