Holset H1C Turbo Questions - Need Help
terrenceLP
81
Las Vegas, Nevada, United States
Building a custom Holset Turbo setup using a H1C Turbo on Stock Spec 7M-GTE.
My turbine housing is basically a hx35 with the 4 bolt mount and V-Band exhaust rear.
Smallest Turbine Housing I can find is 12cm - http://www.gillettdiesel.com/12cm2non-wastegatedturbinehousing-3.aspx
Any smaller is hard to find. These are also non-wastegated.
Question: Should I be concerned with the size of stock turbine housing?
What are the recommendations for the 3.0l 7M?
9 cm2 = 0.65 A/R
10 cm2 = 0.73 A/R
12 cm2 = 0.89 A/R - Holset Part Number - 3524123
14 cm2 = 0.97 A/R
16 cm2 = 1.13 A/R
This is the turbo -
$T2eC16h,!)cE9s4PvnYyBRVI11(WKg~~60_57.jpg$T2eC16N,!yME9s5qF8SnBRVIzn,GLg~~60_57.jpgh1c-holset.jpg
IRACEMYCOPCAR
HOLSET MAFIA HX52
Jan 27, 2008
88
SOUTH CAROLINA
12cm2 should be fine, i was running an HX52 with a 16cm2 housing on a 1.5JZ (same 3.0l displacement) and it was great, i had full spool by 4000rpm so you should be between 3200-3500 with a 12cm2, i wish there was a 12cm2 housing for the HX52 i would have loved it even more.
