Holey advanced timing Batman!!!!
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
so ive been driveing my car with the new motor for about 850 miles now and ive been trying to work the kinks out and get it running better. but i dont have a timing light so today i went over to my friends shop to see if i had a timing issue. well... my timing was sat at 96 advanced!!!!!! wow my friend at 1st said theres no way thats right is shouldent be running right now! so we checked to make shure the pully was lined up right and everything checked out right. so we tuned it down to 80 and it runns alot better now but i need to adjust the cam poseson sensor when i get the time so i can get it down to 10.
so has anyone ever herd of a running car at 96 advenced timing? no wounder it was running like crap... lol
Linkstar07
757 Traveler
Apr 17, 2007
32
Windsor, VA
Holy crap is right, Batman! I am thoroughly surprised that the car even ran. Glad you figured it out and should def be alot better now. I've def never heard of timing being that far off before.
lppro
Apr 21, 2007
895
ya it was crazy.... this is yet another lession... never let a old school chevy guy work on your car.... the guy flat out lied to me... "ya ive worked on those supras before no problam" BS!!! never again....
Techno Supra
Hardcore DJ
I had a similar problem with a much worse outcome when I first got my supra and then the notorious BHG a month later. The guy (old boss' brother in law) was great with domestic muscle cars and assured me he could handle mine. He had the head re-worked and ordered a 1.2 mm HG without checking how much was taken off the head and block. Once I got the car back I was throwing codes everywhere and when the engine was pulled apart again you could see where the pistons were slapping the valves/head. Everything was chewed up. :3d_frown: Lesson learned.
lppro
Apr 21, 2007
895
that sucks... but i basicley told the guy how to put the motor togeather... and supplyed all the parts... and i worked on it with him for atleast 10 hours.. in the end he was 2 grand richer and i had a supra that was running like crap... but like i said lession learned... the only person that works on my supra now is me and people i know and trust.
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
wow 2 grand shit i only charge 500 dollars if you supply all the parts
<-- owner of 301 motorsports.
Frank Rizzo
478
Fixing your girl's car
I bet they didn't use the right timing light at your friends shop.
If you want to set it yourself (like you said, right?) here's what you do. Go to the parts store and buy a simple inductive timing light, and some coolant (don't forget distilled water, tap will not cut it). Take the upper radiator hose off along with the thermostat housing. Take the upper timing cover off. Take a 19mm socket and breaker bar, spin the crank until the cam matchmarks line up with the notches on the inner timing cover. If this does not happen, go to the dealer, buy a new timing belt and install correctly. Take the CPS cover off, verify the CPS rotor is pointing at about 1 o'clock, about 1/4" away from the top signal point. If this is not correct, go to the dealer and buy a new o-ring for the CPS, take the CPS out and install it according to the TSRM--->line the drilled mark up with the notch on the CPS housing. Reassemble everything. Jumper T and E1 terminals at DIAG box. Connect inductive timing light. Start engine, verify 10 degrees of ignition timing, if not, loosen CPS bolt and spin it. Drive vehicle and enjoy.
lppro
Apr 21, 2007
895
my mechanic freind has been a toyota mechanic for 16 years.. and know supras very well. so i know he knows what he is doing. we used a snap on timing light and yes the the cam marks line up and so dose the crank pully mark. im goind out right now to play with it.. he let me borrow his $300 timeing light (=
lppro
Apr 21, 2007
895
ya the timeing was deffinatley that far off.. i set everything at 0 and TDC and took the cover off of the cps and it was a bout an inch and a half away from whare it should be.... so i adjusted it and put it all back togeather and it fired right up and runns great! i hooked up the light and took a look and after minor adjustments it was right at 10. so all is good!
