HKS SSQV fitting gone!
steven89
892
Houston, TX
haha, new SSQV is like 150-250 and id rather either fix this one, or buy a knockoff and take the back part of the housing and bolt on.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
id do what al recommended, drilling and tapping for 1/8 pipe thread is the way to go. the threads also give you a bit more insurance so the fitting won't work its way out of the hole again.
steven89
892
Houston, TX
yeah, but i cant find any pipe/bolt that size. So that makes it a lot harder.
steven89
892
Houston, TX
any idea where to find tube,bolt or anythin to redo this fitting? ive already checked the autoparts store and home depot.
steven89
892
Houston, TX
Alright, so i gave it to my friend to take to work ( he works at some american V8 shop) and he drilled a bigger hole and fit a brake line into it. I just JB welded it on and i will see tomorrow how it works.. What you guys think of this fix?
steven89
892
Houston, TX
MK3Brent said:
I would have just tapped it, since it was drilled... but hey that's me. :)
Did you just simply drill it w/o taking it apart?
nah, took it apart and have a cut & bent brake line goin to it JB weld curing now though :D
Clip
Oct 16, 2005
2,738
9
Virginia
ive never had jb weld work for me...ever. ive followed all the instructions but couldn't get it to work on four seperate occasions.
williamb82
907
4
Tampa, Fl.
jb weld has always worked fine for me. i used it to attach 2 peices of aluminum sheetmetal to a 7mgte block that threw a rod. ran it for 2 years before i found another bottom end to replace it. cheapest fix i ever did. put a freed rod and piston i got from a friend in it, replaced the 4 bent valves for ones from a junk head, reused the mhg, reused the rod bearing and rings, new oil pan and start which i already had. lol. just have to clean both surfaces really well first. i use acetone on a rag to remove all residues. worked great. that motor on a stock turbo at 8psi ran a 13.67 @ 96mph with uneven compression. not bad imho. only mods were the 3in exhaust from the turbo back and hks smf. everything else was stock.
steven89
892
Houston, TX
Well, heres my fix. Just tested and it works! Woot!
Excuse the Y fitting.. its all i have for now.
