I have a first generation EVC, and while I was super excited to wire it in and experience 17 psi of boost to red line, I got a little more than I bargained for. It gave me 15 psi of boost when I was supposed to give me 8. No control over the boost level on any setting. So I dug into it a little bit.
I was assuming best case scenario, and the line I hooked into the EVCs MAP port had a check valve in it, and it was never seeing positive manifold pressure, therefore keeping the valve sealed. Unfortunately, that was not the case. So I dug a little deeper.
Removing the 4 socket head cap screws holding the center portion of the valve together, I revealed the stepper motor at the heart of the EVC. Powering on the system revealed something incredibly strange. Every 5 seconds or so, the pin in the stepper motor would extend itself as far as it could, which would seal the valve. You could push it back in and it would come right back out in a couple seconds.
So I thought, okay, it's only seeing ambient pressure, not the pressure I had the valve set for.. So I grabbed my handheld vacuum / pressure pump and gave it some pressure on the MAP port. Same deal. No idea what's going on, as the stepper motor seems to be doing it's job, just at the wrong time. But I just don't know if it's a controller, stepper motor, or map sensor issue, or where to even start diagnosing this issue.
I called HKS USA and they were ZERO help. Basically they said that nobody knew about those units and HKS doesn't even care anymore since its over 3 months old or something along those lines. Definitely not how I would operate my business, but I'm also not HKS. It's really making me rethink my goals with this car.
Anyway, any help is appreciated! If anyone knows how these things work or could help me work through figuring it out (ie what signals do what) that would be so much help. Thanks in advance!
