You CAN reuse the metal gasket, just make sure all of the Viton, or polyelastomer flourine coating or whatever it's called is all stripped off, then you can spray with Brake Quiet or Copper Spray.
Oh course you still need to make sure both the head and block surfaces are totally straight, and that the RA is within spec, if not below spec.
