I just changed the clutch on my mk3 along with a new slave and master cylinder. I bleeded the lines, i adjusted my pedal and everything was put in properly. My question now is it doesnt go into gear. What's going on?
Did you check the fluid level in the tranny? You always loose some when you pull it.Sisco;907968 said:ok i took it all apart and put it back together, I doubled check everything, all the gears are going in now except for my reverse. It just grinds and doesnt go in. I dont what else to think could it be a need a new tranny?
Sisco;908391 said:how many quarts thoes it take? im going to check that again..
