In the somewhat near future (depending on how fast i can get a new clutch, and pay for it) I'll be getting regrinds from schneidercams.com after contacting them, they have over 5000 different grinds i can choose from. though i don't know the lift and other facts, they have been selling 274 racing cams for years. these are regrinds and i already have the lash caps (its a 6mm riser that sits under the valve bucket to bring it closer to the cam..... since they grind some off). anyways...... here's my set-up
pt61 .68 turbine ar on greddy manifold
3.5" dp and tp
rsr gtII
map-ecu
supporting fuel mods
full hard pipes and bigger intercooler
i don't have a way of turning up the rev limiter yet, and i was wondering if this cam is a little lofty for my needs. the car is a serious street car that does 95% of its work on pump gas. here is a pm from a guy that used the schneider cams years ago
"I liked them. They were very streetable but they had a serious lope to them. I was using them with a ported head SP57 turbo kit and all supporting mods. For the money you can beat them.
Erin"
tell me what you think. im not set on these 274's, but i wouldn't mind a rise in the power band if it means an extra 40whp on pump gas (thats what ive been told to expect). i say this because they can grind me pretty much any demension that i want. so i bet i could just get the bc 272, or 264 specs and have them replicate it. right now my turbo falls off a little bit before 6.5k rpms. watch the video here to see what i mean. http://www.supramania.com/forums/showthread.php?t=51999
i have yet to see how the car feels on higher boost....... sorry for being so long winded, but thanks in advance.
...... also, i plan on getting the head ported when i rebuild my motor with forged internals
3.5" dp and tp
rsr gtII
map-ecu
Erin"
