HELP: What jz harness is this?!?
Albert
May 13, 2009
1,710
Tempe, AZ
Okay I ordered a harness of eBay claiming to be a jza70 m/t harness.
Things arnt adding up, and I wanna see if any of you guys have a clue to what it is.
Ecu plugs: look like jza70 but there is only 3 plugs. There are suppose to be 4 plus a flylead plug?
4 body plugs: 2 look like b1 connectors, then there is a white and orange plug?
First thing out of the firewall is map sensor(jza70 or jzz30) and ignitor plugs?!
These sets of plugs go through the plenum to the tranny area: auto tranny?
And to add the cherry to the cake: a TPS plug with a set of traction control plugs for throttle body? Jzz30?
Albert
May 13, 2009
1,710
Tempe, AZ
It has two knock sensors as if it is turboed. Has jz coil plugs, oval style alternator plug..
