I recently built my engine from the ground up, and used the chilton manual for everything. I just recently read that BHG's are due to improper torque to the bolts, i followed the book and set them at 58 ft/lbs. it ran fine for about 2800 miles and then started actin like a bhg, lots of steam pouring out the pipe, on hot starts only, and the symptoms disappeared after about 30ft of driving. I retorqued the bolts (they were 10lbs loose) and it seemed fine again. then one day it started again and it got worse. and then (all on the same trip) it started reading low oil pressure, and within 5 min's it was almost 0, i made an underpass u turn and heard a knocking, instantly i shut her down and coasted into a parkin lot, and towed her home. cant see any water in the oil or vice versa, tried to spin the pump drive gear with an air ratchet and no oil could be seen comin up to the cams (dont know if it's even possible to do that just thought i would give it a try) im gonna go ahead and pull the motor. just wanted to know if any one has any input on this. oil pump? pickup? drive gear assembly? maybe the bhg has somethin to do with it? im out of theories
