help on oil pressure gauge
Skadaloz
32
Ephrata,PA
well just did my jdm 7mgte swap...got it running and what not...but wen i turn the key to on the stock oil pressure gauge goes over 120 psi and now its stuck pass 120 psi and wont more no more...if i remove the jdm oil pressure sender unit out and replace it with my usdm stock oil pressure sender unit would it go back to normal?
Supra90gr
116
Connecticut
What jdub said... I suggest an aftermarket oil pressure gauge.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
my gauge used to act funky when I swapped over a JDM engine into my 89, it would rise to the top then slowly descend. When the 86.5 received it's JDM engine, the gauge wouldn't move at all. Now finally when I swapped in a JDM engine into my 92, I made sure to change the oil pressure sender and it works like stock...
not sure why they're different, maybe metric vs standard, who knows..
Skadaloz
32
Ephrata,PA
welll i just switch it out and i guess i did fry the stock oil pressure gauge...still stuck above 120 psi...well i guess ima have to buy a aftermarket oil pressure gauge...theres this guy selling one for $30 shipped but its mechanical...so what all do i have to do to get it to work?
A70BoosTFienD
A.K.A. Knight Rider
Oct 28, 2008
224
Orlando, Florida, United States
i actually had the same issue the op described but it wasnt due to a jdm ops. it was due to the signal wire melting on the header. cut the wire hoping it would drop but it stayed at the top. wired it back up 2 weeks later and no change. fired gauge?
