Help - No start
Silent Smith
Jerk.
Nov 30, 2005
59
Mississauga
I jsut did my headgasket and the motor cranks but will not fire, I( cannot hear the fuel pump at all, There is the speed sensor wire and a randonm wire hanging is on of these for the fuel pump?
Any help would be stellar
redsupra_Dragstar
redsupra_dragstar
Jan 26, 2006
14
Tulsa
i suggest you plug in those wires to wherever they go. if it cranks, catches and dies, more likely it'll be your wires. other than that i wouldn't know.
SS: The way our motors are set up is the pump doesn't run until the ECU sees an RPM signal.
Post a pic of your suspect wiring as these cars have lots of "spares" and they may not be the cause of the problem.
KINGPIN33
183
Canada
+1 for being in Sauga. i live there too.
Grab some picks of the wires you are talking about.
Also, check your cps installation and timing.
