help me maftpro
lian
58
ottawa
ok maft pro, speed density harness and lc-1 wide band are in.
the car ran ok with only the maft pro in but now when the car is idleing and i go to rev it it wants to die out before it finnally revs up .
i think its is running super rich.
the lc 1 wires are red too maft pro pink ,brown to maft orange . and blue and whit grounded on the engine ground yellow is not hooked up .
what is to be done with maft purple i have a small feel it is too blame when i set up the lc-1 it was fine.
and does the white wire have anything to do with the purple wire on the maft pro.
sorry for the very confusing sentence work
lian
58
ottawa
GrimJack;1054205 said:
How can you *think* it's running super rich if you have a wideband installed? Why don't you know exactly?
becouse it pour smoke out the back and you can really smell the fuel
lian
58
ottawa
GrimJack;1054210 said:
So... what does the wideband say???
i got the maftpro package without the wide band display i thought hooking the lc-1 to the maft you could get readings on sensor monitor.
and i got to buy the special usb cable to hook up to my laptop.
i just ned to get it drivable for tuning on monday.
are there any settings i can adjust on the maftpro
and thanks for any help grim
lian
58
ottawa
GrimJack;1054227 said:
Yes, you can display it on the MAFT Pro using the sensor monitor page.
do i have to enable any settings to get the display and what readings should i get on idle
oh ya did my lc-1 wiring seem correct
i just checked and i am not getting a afr reading on sensor monitor on the maft pro.
i now believ it is the speed densisty you can look in the manual at page 16 tunwe responce
lian
58
ottawa
Fletch124;1054490 said:
List your settings please and what version of software your translator is running.
http://www.supramania.com/forums/showthread.php?t=38780
ok im runiing 440s and the car runs fine again if i take the speed density out.
i have not adjusted from the main setup as i have not found a setup on the net.
what settings do i change on the maft pro after i install speed ddensity.
im running 4.4 and my afr flucuate alot from 7.9 to 21.1
lian
58
ottawa
is there anyone i can call for help im ripping my hair out just trying to get a conection to my laptop
