ok... in an attempt to try to get the car to boost more than the 13 I managed to get it to boost by shimming the wastegate and installing a moderate sized T I put a bigger T in trying to up the boost. I re-assembled, and went for a road test. Was boosting too much. Going over 20 and hitting fuel cut. I brought the car back home, disassembled, removed the shims and put everything back together. I go to start the car now and it wont go. It turns over but no start. I see fuel pressure marked on my fuel pressure regulator so im assuming i got fuel pressure. I disconnected the ECU and reconnected it and nothing. I checked the connection for the AFM wich to me seems a bit iffy but after making sure it was connected using some channel locks, still no start. Anyone have any idea's? :1zhelp:
