help codes
tyler
74
canada
im throwing codes
14
IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU
--IGNITER/IGNITER CIRCUIT
--IGNITER AND IGNITION COIL/CIRCUIT
--ECU
22
WATER TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
--WATER TEMPERATURE SENSOR CIRCUIT
52
KNOCK SENSOR SIGNAL--OPEN OR SHORT IN KNOCK SENSOR SIGNAL
--KNOCK SENSOR/CIRCUIT
ECU
now my questions are how do i fix these i think the knock is because the previous owner was running 87 octane...
now even though throwing all 3 codes the car still runs and drives fine? not the way it should but it shouldnt even be running?
any help greatly appreciated
drjonez
the motor city
www.4cefed.com
tyler said:
im throwing codes
14
--ECU
22
52
ECU
as stated, clear codes and see what comes back. the car won't run for long w/a code 14....
code 22 is easy enough, replace the sensor and/or the wiring....though chances are it's just the connector. it's the 2 wire connector on the side of the water neck.
code 52 = bad knock sensor wiring. see the SOGI tech tip.
no, running 87 octane will not throw a code 52.
tyler
74
canada
heres some more info on what it does.. as soon as you start to boost it studders after 3 ish psi usually? the coolent disappears to never never land and it still has 120 compression across all 6 cyll so where is the coolent going is the ignition code causing the studdering? or could it be a coolent seal in the turbo causing the studdering? ahh i dont know im not used to supras
onemancrew
67
Sydney
I got the exact same codes but my car runs fine,,, better than ever before actually. Resetting my codes doesn't work either... Did you ever get this problem resolved?
