help! car won't start!
mizuboi
86
cypress
okay so here is my problem... i just finished installing a new motor and was going through my checklist to see if i had missed anything. Finding that everything was in order i went to go blip the engine to get some oil flowing before actually starting the car and i get complete power loss. By that i mean all of my electronics go out and then right after i let the key return to the on position my power comes back.
any ideas of what might behappening? also i found that i'm getting a spark from the battery terminals. if that helps at all...
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
whats the battery voltage at? sounds like there is not enough juice to crank it
mizuboi
86
cypress
yes i do have the battery grounded to the engine. The voltage acording to my meter says 13.2 volts so i don't think its a lack of volts, and even if i had a lack of volts wouldn't it just try to crank and not spark...?
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Might be a weak connection on the battery terminals.
I had the same problem where i have power to everything at the ON position, but when i turn the key everything cuts off and nothing happens then when the key goes back to the on postion i get power to everything. I checked my codes, and came up with 51 (ac signal switch) so i just said screw it and hooked up a switch to the starter and thats how i went on lol.
took the dash out later on and found that the ac signal wire (white/black dots) was fried all the way through.
mizuboi
86
cypress
that sounds like a good idea maybe i'll do that
mizuboi
86
cypress
okay now i have a new problem! it tries to start but boggs down like it wants to but doesn't any ideas? my oil-pressure sensor is not functioning can this be the problem too?
mizuboi
86
cypress
it is... i was trying all day to get it started and nothing.. well it almost started once or twice but it just seems like its right there about to start but wont.
i want to take it to a shop but if anyone wants to come down and fix the problem give me a price and i'll pay for time and provide food! i need this on the road soon! and i'm also not sure about a lot of things on my car... well i'm actually exhusted right now from working on the car and not really making any sense... T.T
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
Make sure your cps is aligned correctly because it will not start if it is not, and that you have the engine bay harness wired right. The harness that goes to the starter and alternator plus ground.
mizuboi
86
cypress
i was just doing some searching and it just dawned on me that the cps might not be aligned correctly! and then i saw your post! any tips on how to do this? i've done some searching and really haven't come to any conclusions
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
1- Set you motor to TDC on cyl #1 (align the mark on the crank to the 0 degree mark, and the cam marks align with the groves on the cam shield)
2- Unbolt you CPS (only one bolt)
3- Pull the CPS out
4- There are 2 gears Big (Stationary, it dont spin) and (small) Gear at the end that actually spins. On the Big part, there is a notch at the tip. and on the small gear there is a hole drilled. allign the drilled hole from the small gear, with the notch on the big gear.
5- Reinstall the CPS in as straight as you can to where the hole in your head is somewhat in the middle of the slot on the CPS (where the bolt goes).
6- Hand tighten the CPS into place (bolt in the middle of the slot) and have some one crank the car, if it doesnt start, loosen the CPS bolt a bit and shift the CPS up or down a little bit while someone is cranking the car.
Also you can use this as a guide
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=22
Hope this helps.
-Saif
mizuboi
86
cypress
3- Pull the CPS out
Hope this helps.
-Saif
thanks man! i will do this after i get home from school!
