I posted this same thing in my build thread but nobody responds in there so I thought I would try in here because it's putting the pause on my build. When installing the lifter buckets, a lot of the intake ones were very hard to get in. I had them all in order, so I know they went in the same bore or whatever, but they kept catching on the valvesprings. One would NOT go down for anything, but I finally shimmied it down but it wouldn't rotate. Bad move. I was thinking once it has more oil and is warmed up it will break itself free and bounce back from the spring, but as I bolted the cams down it just went down and when I rotated the cam it stuck down there. It is very tight and I don't know what's wrong?! HELP! Do have have to take everything back apart and take the head off to fix this stupid bucket??
-Chris
-Chris
