HELP ASAP!
huntin5L
Niles, IL
Guys what did i break here, looks like a vacuum switch, but not sure. Can I get this at a parts store or do i have to go through the dealer? Let me know asap, i need this fixed, because my turbo kit is going on this tuesday.
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
Valve-Bimetal switch, for emmissions.
Dealer part, although someone around here might have a good one thats not old and dry rotted.
I bought one as well, #90925-05068
Its actually not "essential" and you can do without it until you get the part.
Piratetip
1,179
70
MKE, WI
Yes, just make sure there isn't any dirt going in there.
I would plug the hard line on the 3000 pipe.
Like I said its for emissions only, its not an essential part.
Follow the line, it goes to the charcoal canister, then to the gas tank.
Mk3runner
2,033
Nor Cal
junk yard is where I got mine. I went to the dealer when mine broke and 50 bucks is a grip. so went to the junks and found one. its a common part on toyotas so it doesn't need to be vehicle specific.
supraman7mgte
Shut up,bitch!!
Sunny California
try jay marks toyota,you might even get a discount! just buy it new,that way you dont have to worry about replacing it with one that might be as bad as the one you replaced.
