Help!! Advice on 2JZGE (non vvti) Aftermarket Cams
jmcboost
Missouri
So, I just got in some 2JZGE Brian Crower 264 cams and they are for VVTI engines only. I talked to Brian Crower and they do not make a non VVTI 2JZGE cam. Does anybody have a solution or now where I can get a set of 2JZGE non vvti 264 cams that will work?
Vrank!!!
hahahahaha
Dec 17, 2009
136
TX
You can't use the vvti ones? not the same journal size? or maybe just the exhaust cam at least?
jmcboost
Missouri
Yeah, I found that out. It looks like the only option is a hard welded cam. I know that Web Cams, TTC Performance and Crower all custom make them for $850. I just want to confirm if TTC performance is good and reliable, as far as actually getting the parts in the time frame they say.
jmcboost
Missouri
Just an update...I sent my stock cams off to Web Cams to get them hard welded to a 268 duration. So I'll let everybody know how they work out.
Ran hard welded cams in my 7M for many many years/KM's and they were perfect showing 0 wear or issues even after a few engine failures and constantly being run to 8500!
jmcboost
Missouri
Good deal, I think I will be very happy with them. I probably won't run very high RPM until I can upgrade the springs and retainers.
