head wont come off
ginglesturbo
Boost Nazi
Dec 1, 2007
129
Charlotte N.C.
i have a small problem....i got all the head bolts off now...but the head wont budge...what is the best teqniqe to get it off? i dont wanna pry it with anything cause im scared it will warp....any tricks...tips would be nice
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Do you have an engine hoist available? If so, hook up a chain to the lifting points on the head and use the hoist to raise it off of there.
Other than that, all I can think of is using a mallet to loosen the head from the block then try lifting.
ginglesturbo
Boost Nazi
Dec 1, 2007
129
Charlotte N.C.
na i woul know if it was something just holding it but it wont budge.....its like the bolts are still in it....i dont have an engine hoist either ...i could borrow one from a freind .....has any one did the mallet trick before?? i dont want any bad results..i want this damn thing off!! are they ususally this hard to pull?
ginglesturbo
Boost Nazi
Dec 1, 2007
129
Charlotte N.C.
by the way....what should i use to clean off the old gasket...i got a putty knife i think it should work good....the gasket was blowed in like 6 different spots...so its stuck on theere pretty good
Nov 29, 2006
89
Vacaville, CA
razor blade...and patience.
P.S. Try not to scratch the bottom of the head or block. I remember my first bhg i was trying REALLY hard not to scratch it and right when i was almost done; i scratched the fucker.
You know there is a built in lever point on the front right hand side of the block right where the infamous MHG Rivet is that you can fit a screwdriver into and pop the head? ;)
