Head Gasket thickness selection
Seen this question asked on many occasions, here's the HG's for dummies version ;)
1) Stock HG = 1.37mm compressed
2) Stock head = 116mm deck to valve cover surface
3) Stock block = 198.5mm from deck to main bearing saddle
If 2 and 3 are less that amount needs to be added to 1 to retain the stock compression ratio and squish/quench.
  • Like
Reactions: Fola
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Ummm.....
Is this aimed at me? ;)
Good Information for people trying to retain the Factory Static Compression with factory pistons.
With aftermarket pistons: To figure static compression; you're better off having the combustion chamber volume measured after headwork using this method, then use that figure, your piston dome volume, bore size, stroke (always 91MM's), projected head gasket thickness, head gasket bore diameter, and VERY VERY IMPORTANT measured piston deck clearence; plug it into this equation, or using this online calculator.
You can find most of the Head Gasket Bores and thicknesses on this site. (Titan Motorsports is 86MM Bore.)
But this should all be common knowledge. ;)
mk3 turbo
mo
Hay guys im trying to get my car back to gether and looking at the formula above is the compresset gasket really 1.37mm thick that just seems wrong but please help
suprarich
Guest
Nov 9, 2005
2,187
ohio
The 3 new un-used vintage asbestos OEM 7m Headgaskets I have on hand are 1.270mm thickness with a 84.633mm bore size.
A current 2010 OEM Toyota head gasket is 1.524mm thick with a 84.709 bore.
There could be many other OEM sizes in between these as we all know Toyota has used different suppliers over the years.
