I just wanted to verify that rounding down to a HG size will not cause any problems.  My block measured out to 198.35, which is .15mm off stock after machining.  The head was 115.25 or .75mm off stock.  I need a 2.27mm HG.  Cometic HG's do not come in that exact size, but after searching I saw IJ said it's ok to round down a size.  If I round down from 2.27 to a 2.0mm Cometic MHG, will I be ok (I didnt see any other closer sizes on DM or HPF)?  Will this significantly affect my compression (i'm running forged internals)?  I know this is a frequent question, just want to verify on the rounding down before I place my order.  Thanks in advance.
