Head Gasket reuse question
TweeT91109
738
Tampa, Florida, United States
Just a quick question about reusing a head gasket. It hasn't been started on, just torqued down to 85 ft. lbs, using ARP head studs. It is a composite oem replacement gasket, so the question is, is it ok to remove the head from the block after its been torqued down. Then reuse it once I have some head work done, or should I get a new one?
Prolly going to need new. The material might come up or deform.
Not something to chance really. You could try it if you wanted tho if it looked good.
