Just a quick question about reusing a head gasket. It hasn't been started on, just torqued down to 85 ft. lbs, using ARP head studs. It is a composite oem replacement gasket, so the question is, is it ok to remove the head from the block after its been torqued down. Then reuse it once I have some head work done, or should I get a new one?
