Head Gasket Choice?
Wildfire007
139
Cullman, Alabama, United States
First I'd like to say I tried searching for the answer on the forum and google and couldn't find a straight forward one.
So my cherry has been popped and I have my first 7m-gte bhg. I was going to go with an oem hg and arp studs but does anyone know if its composite or graphite? And which is superior? Going for a cheap repair and trading the car to a friend. So metal hg is not an option and cometic is a bit too high.
digihonk82
118
Olathe, KS
Im pretty sure the composite refers to the multiple materials used within the gasket structure because theres the fiber board and then the cylinder steel rings and then the copper coolant channels all in one gasket :)
Grandavi
2,663
Calgary, Alberta, Canada
Cheap + 7M doesnt usually work. Make sure the head and block are prepped properly or you risk losing that friend.. lol. The head gasket itself isn't as much of an issue as the actual engine prep before applying it. If the head and block are prepped correctly and the head bolts/studs are torqued correctly, the engine wont suffer from the same issue. Tons of write ups about that.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Use oem gasket from Toyota (which is a graphite composite), take the head to a machine shop, clean the block with gasket remover and a razor scraper.
If you have the ability, check the block for straightness.
Recipe for cheap, relatively good success.
Sent from my ADR6400L using Tapatalk
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
+1 graphite/composite refer to the same thing. Go with OEM or FelPro which is equal in quality. If you re use the stock bolts, torque to 72 ft lbs and if you use ARP hardware, torque them to the ARP specs with the ARP lube, it is critical you follow the instructions from them to a tee!
Wildfire007
139
Thanks for the help guys. I'm trading the car to him and he knows full well the risks of the vehicle and is fine with it. I am moving cross country soon and didn't trust the old girl to make the drive, and I am looking forward to getting a 91-92 model mk3 once I'm out west. Can't wait to get my next Supra and do a 1jz-gte swap!
