Having an odd issue, miles from home. like almost 200 miles. yeah no money, pls help
Nihiliz
Die Hard Supra Fan
Jul 23, 2007
307
United States
www.facebook.com
SO im driving to mydads far away,. car was running healthy minus its getting close to bhg, so anyways, im driving along the highway, and this neon srt4 dose a ricer flyby, than falls back,. keeps reving it etc,. was getting annoying. so i was like okay buddy. (dusted him by like a mile? LOL) so anyways after i letoff and start breaking...... something breaks LOL. was no noise of anything breaking but now like,. car vibrates,. and like if u try to keep a steady gas with the pedal,. it cuts out in power than gets power. if u geton it. it feels like somethingis holding back hardcore. as for lower gears driving around it dose the same thing,. im thinking its the driveshaft is like fucked,. or u joints. but im honestly not even sure.
---------- Post added at 11:03 AM ---------- Previous post was at 11:02 AM ----------
as for people thinking its fuel. its not its not a cut out of a motor/fuel,. i could put it in nutreal and rev that honkey all i want, idles perfectly. etc.
BOOSTEDSUPRA
THE DRIVELINE GUY
Jan 4, 2007
308
turlock, calif
it will not be the driveline. a driveline issue isnt going to keep it from reving up under a load. sounds like a definate boost leak to me. even though you can rev the honkey outta it in neutral, doesnt mean that when under a load, i.e. the car is spooling up trying to push 3500 pounds, the boost pressure isnt trying pushing off a coupler or something. reving it in neutral doesnt produce significant boost to really show a boost leak.
this would be the first thing i look at. and chances are a bhg would still allow the car to boost and pull decent.
Nihiliz
Die Hard Supra Fan
Jul 23, 2007
307
United States
www.facebook.com
yeah i replaced all the couplers, piping and used t bolt clamps, checked over everything, even tps, throttlle body, intake manifold,. its all good. it gets boost etc. but something is hesitiating, and when u get 40+ MPH, the car vibrates like hell on earth.
Nihiliz
Die Hard Supra Fan
Jul 23, 2007
307
United States
www.facebook.com
lol was a boost leak,. tps blew off, and i was a retard for not even looking at it,. well it dident fully blow off lol,. just the bolts wernt there and it was still attached somehow. but yup lol
BOOSTEDSUPRA
THE DRIVELINE GUY
Jan 4, 2007
308
turlock, calif
....its just possible something let loose in the engine. if your 100% sure you have no boost leaks, take a compression check. pain in the ass i know, but would tell you (us) alot about whats going on.
figgie
Twin Cities, Minnesot-ah
Nihiliz;1540747 said:
tps blew off, and i was a retard for not even looking at it.
TPS blew off? Throttle Positon Sensor? I have seen these cars take 40 psi of pressure and NEVER has a TPS blown in any case. You sure you tightened that sucker down? Sounds exceptionally doubtful.
