has anyone ???
karlmk3
336
thornton
soi found this looking around online and was wondering if this is true or not
Originally Posted by dcrusupra
The harness on the 1JZ should hook right up to the interior harness. The only problem is that you'll have to lengthen the harness by about 18".
this part??? ->
thats the old method, people nowadays drill a hole near the throttle cable and run the harness through there and its fits right behind the glove box in the stock location but just flip the ecu, cleaner looking engine bay too
JonoTurbo
Going for broke
CT
I've done several swaps using that method, and I believe Driftmotion uses that method as well. It sure beats extending all those wires, with this method you have to extend somewhere from 18 - 35 wires depending on options.
Also, as far as that first quote, one of the body connectors under the dash is mostly plug and go(if you have a 90+ car) but you will have to redo the rest.
karlmk3
336
thornton
i have an 89 also i have one more question as for doing the powersteering lines i can just use themkv supra correct thank you guys for all your help i have some parts left ove from the front clip and some stuff from the 7mge i pulled if you need something let me know
JonoTurbo
Going for broke
CT
I've never heard of using the mk4 lines, so I can't say if they work or not. I can tell you that the cheapest option is a pressure line from a 94 Nissan Maxima. It costs about $30, and works great.
karlmk3
336
thornton
sweet thanks so much
ma70mkiii
139
ohio
u can use the mkiv high pressure hose or go to driftmotion and buy a stainless steel braided one from aaron. either way works great.
JonoTurbo
Going for broke
CT
karlmk3;1443621 said:
singal or duel over head cam for the pressure lines on the 94 Nissan maxiym
The dohc hose has been confirmed to work, I believe the sohc hose should work as well. They are very similar, I think they might just be different lengths.
karlmk3
336
thornton
ya when i went to the parts store all she would say is the price shes all i dont know the diff when i sked to see the 2 shes all well just pick one see if it fits and then if notbring it back so ya she wasnt very plesent
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
I can vouch for what Jonoturbo says, we did it on my car (he did most of the work) and it came out great and looks super clean without the harness in the engine bay.
karlmk3
336
thornton
sick i wish i could get this done i cant even ge the moter to line up on the moter mounts. then i still have to figure out where to drill the hole can soe one post a pic please
