my psychic powers tell me Ideal is going to make a post about the Q45 throttle body....
OOOOOOHHHHHHMMMMMM!
OOOOOOHHHHHHMMMMMM!
theWeezL said:my psychic powers tell me Ideal is going to make a post about the Q45 throttle body....
OOOOOOHHHHHHMMMMMM!
Reign_Maker said:I have a thread from SF saved in my favorites to wire it up, but SF has been down... http://www.supraforums.com/forum/showthread.php?t=321855 I dunno if you've seen this or if this is what you need, but Im gunna be right behind ya on wiring mine up soon here...
Idealsupra said:even though SF is down...im sure ive seen that...thats the post with the wiring diagram right?
i used that to wire it up but he said to spec it he used his afc (which im not using) and he still didnt get it 100% right....
soooo im wondering if theres a way to spec it out like the stock one with a feeler gauge and the set screw on the tb....
rakkasan said:Huh? The 1J doesn't use a Q45 TB.....
:biglaugh:
Reign_Maker said:Jayson is the Supra mechanic whore of central florida... Im gunna hafta hire his, um, SERVICES here soon...![]()
If the TPS was securely installed in the TB & the TB was sourced from a running car, I wouldn't mess with the adjustment at all...odds are it's close enough to spec as is.Idealsupra said:ill do the 1j swap in the red car for you for a pricejust bring the car here have the clip shipped here and then come pick the car up in a week
ANNNNNNNYWAYS BACK TO MY ORIGINAL QUESTION DAMNIT!
Cool beansturbogate said:.....all you really need is a voltmeter to adjust the TPS sensor position/voltage range mentioned in the write-up.....
