Has anyone dynoed their stock Mk3 supra turbo?
allfans26
26
Lawrenceville, Georgia
This is just a curious question that I had lingering for a while. I know that Toyota advertised 232 HP @ 5600 rpm with later models of the supra (1990-1992). I was wondering what the WHP would be on a stock. I know about the 15% - 20% HP loss due to automatic/manual transmission and crank shaft translation but I never knew a real number HP readout at the wheels. If anyone has done one, do you mind sharing your results? Thanks! Since I have a stock supra (auto) I'm expecting 185 WHP off an stock mk3 with respect to 20% HP loss of 232 crank HP. (In terms of stock, I mean straight out of the factory. Sure some air intake mods but nothing too dramatic to increase horsepower/flow.) Is that true compared to your results?
Thanks, Branden
shipkiller
398
Quebec
we saw 173rwhp this summer at a dyno event on a 88 7mgte R154, only mod was a 3" elbow and downpipe. On a mustang dyno mind you.
SupraClaou
846
4
Athens,Greece
damn , that's a big loss of hp... 60 hp drivetrain loss from 232 flywheel hp!
Thought it was around 190-195 to the wheel for the turbo model...
8,877
Mass production prohibits all cars from being either 230/246 or 232/256. Boost varies from automatic to manual with the fluid coupling. Specifically, boost will vary from 4.8-7.5 psi stock. That is by the book.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Well, standard drivetrain losses are 15-25% and I'm sure the motor was worn at least a little bit. 170whp seems about right, unfortunately. Thankfully, you can up that quite a bit with just a boost controller. ;-)
There a thread on here about dyno results. You can get a feel for what's possible with a given set of mods.
allfans26
26
Sweet. Before I use a boost controller should I re-torque my HG just in case or do you think I'm fine with a little extra boost? If I were to go down this route of having a boost controller, I would set my boost limit to 8 (just because AT only allow around 4.8 - 6.8 psi of boost).
(Link to anyone who needs this info: http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=TC&P=5)
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I know the auto is a limitation of power at some point because it can only hold so much torque. I'm not sure where that point is.
For a retorque, unless you just did a HG job, I'm not opinionated either way. Tightening is probably worthwhile, just be sure to follow the OEM torque sequence. You'll probably want to break them all loose as little as possible (1/16th turn or less if you can) right before tightening.
Be prepared for a BHG. It's inevitable on any 7M built to factory specs. If it hasn't happened yet, it will soon.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
Toronto/SF Bay area
My first dyno was 256 whp with hks doe pipe and 65mm cat back with a cat and k&n filter 7-10 psi on mbc
